Crank rattle? Who rebuilds cranks?
Desmo900SS
Post by Desmo900SS »
Can anybody describe what it sounds like when the crank is getting ready to sign off? I have a noise that sounds like a clutch rattle and does change when I pull in the clutch - but it never goes away... Could this be the dreaded crank pin bearing going south? Once I get back, I will pull the clutch down and see if anything is out of whack, but I thought I would ask around too. Who do you all use when it is time to replace the crank pin?
Lumpy
Big ends
Post by Lumpy »
Big ends I`ve heard that are on the way out are pretty unmistakable. It`s an audible knock that seems to get louder when you wind it on. Check for metallic particals in your filter.
Desmo900SS
Lumpy -
So far it appears that the crank primary gear has cracked and is causing a racket. No metal in the filter and the crank seems tight and smooth so here's to hoping a pair of primary gears will cure it!
Lumpy
rattle
Post by Lumpy »
Wow, thats a new one. Lets hope it`s all good in the hood. Law of averages says just now and again you gotta get lucky.
