Can anybody describe what it sounds like when the crank is getting ready to sign off? I have a noise that sounds like a clutch rattle and does change when I pull in the clutch - but it never goes away... Could this be the dreaded crank pin bearing going south? Once I get back, I will pull the clutch down and see if anything is out of whack, but I thought I would ask around too. Who do you all use when it is time to replace the crank pin?
Crank rattle? Who rebuilds cranks?
Desmo900SS
Desmo900SS
