Marzocchi Fork Seal or Seals ?
MartinMille BANNED
- BANNED
Hi All
I have notice in some description on overhauling front forks some use only one seal where other say to use two seal per leg !
What is the correct way one or two seals per leg ?
nottonight68
- BLABBERMOUTH
fork seals
definetly 2 on ss
cafe*racer
- SSD900 Darmah
nottonight68
- BLABBERMOUTH
seals
one up one down ? dont remember that but i think your correct. ill check marzoc drawings
MartinMille BANNED
- BANNED
nottonight68
- BLABBERMOUTH
ssd project
hows the project going?
im doin my 76 ss -ground up
post some pics -im always interested in resto methods and tricks
just got my frame back from painters -all threads full of paint and its hard,had to buy tap set to get bolts in.
had mine since new and it was complete but didnt realise how worn everything was.
had a $6000 budget but i think thats shot to pieces
CHEERS STEVE
CHEERS STEVE
nottonight68
- BLABBERMOUTH
seals
disagree there pete
top seal keeps road gunk out
bottom seal keeps oil in-bewdiful!
nottonight68
- BLABBERMOUTH
seals
only jokin -4 seals needed to keep damian birch new fork boot rubbers clean
nottonight68
- BLABBERMOUTH
fork seals
am aboutvto rebuild my repainted marzocs -1 up 1 down - thiis is the question
- conti-mental
- Mach 3
back several years ago, the original size seals were not available so the common thing to do was to put a seal with the correct OD and ID in there from a yamaha dirt bike, commonly available but 10.5mm tall. The originals are 7mm tall by the way. Anyways, I had a seal manuf make the correct size for me so for the past several years I have had these correct sized seals in stock, they fit both cerriani and marzocchi 38mm forks, 2 per leg, mounted the same way with the seal side UP. Of course you put on a wiper above that on the outside.
cafe*racer
- SSD900 Darmah
