Marzocchi Fork Seal or Seals ?
MartinMille BANNED
BANNED
Post by MartinMille BANNED »
Hi All
I have notice in some description on overhauling front forks some use only one seal where other say to use two seal per leg !
What is the correct way one or two seals per leg ?
nottonight68
BLABBERMOUTH
fork seals
Post by nottonight68 »
definetly 2 on ss
Rick F
seals
Post by Rick F »
always 2 from my memory
I have ceriani, but all the pics of marzocchi (?) all show 2 seals for ss, gt gts darmah etc
I have old parts books ;)
Rick
cafe*racer
SSD900 Darmah
Post by cafe*racer »
Always two seals. One up, one down.
nottonight68
BLABBERMOUTH
seals
one up one down ? dont remember that but i think your correct. ill check marzoc drawings
MartinMille BANNED
BANNED
Ok thanks guys , I just tripped a pair down and they only had one seal per leg , there was no leak but I changed them anyway will have to get another two seal now LOL
nottonight68
BLABBERMOUTH
ssd project
hows the project going?
im doin my 76 ss -ground up
post some pics -im always interested in resto methods and tricks
just got my frame back from painters -all threads full of paint and its hard,had to buy tap set to get bolts in.
had mine since new and it was complete but didnt realise how worn everything was.
had a $6000 budget but i think thats shot to pieces
CHEERS STEVE
nottonight68
BLABBERMOUTH
seals
disagree there pete
top seal keeps road gunk out
bottom seal keeps oil in-bewdiful!
nottonight68
BLABBERMOUTH
seals
only jokin -4 seals needed to keep damian birch new fork boot rubbers clean :-D
nottonight68
BLABBERMOUTH
fork seals
am aboutvto rebuild my repainted marzocs -1 up 1 down - thiis is the question
conti-mental
Post by conti-mental »
Mine have always been 2-up each side - fitted upside down doesn't sound right to me :?
I just removed the originals from a set of Marzocchis from a '75 900ss, and they were definitely both in the same way up
Andy
back several years ago, the original size seals were not available so the common thing to do was to put a seal with the correct OD and ID in there from a yamaha dirt bike, commonly available but 10.5mm tall. The originals are 7mm tall by the way. Anyways, I had a seal manuf make the correct size for me so for the past several years I have had these correct sized seals in stock, they fit both cerriani and marzocchi 38mm forks, 2 per leg, mounted the same way with the seal side UP. Of course you put on a wiper above that on the outside.
cafe*racer
SSD900 Darmah
I stand corrected -?-
Vince
750 Sport [BEVEL]
Post by Vince »
Old racers trick,use 1 old seal and 1 new,no oil leaks and much reduced sticksion,your choise but dont blame me if they leak.
