Tach drive coupling piece detail
Here are some photos and a spec drawing of that funky little coupler piece inside your tach drive in case you need to make one...
Re: Tach drive coupling piece detail
Ah - that's the little piece that likes to fall out and roll under the bench, yes? >:|!!!
Thanks Steve. Could be useful, hope it never is ...
Yes Craig, I bet you can figure out why I needed to make measurements of one then.... So I thought, since I had the info, I might as well post it.
Ah, 'The Power of the Web', eh Steve? Good, init?BevHevSteve wrote: So I thought, since I had the info, I might as well post it.
Might want to do the same with the Oldham coupler for the shifter box too! They seem to disappear when things are apart for a while.
Amen to both bits!!! Amazing what nooks and crannies they can disappear, or rather, fit into!
RAD
