Hello.
After a few years of collecting dust (both the bike and me), I am starting to think about getting my 860gt back on the street. When I last rode the beast, it was running pretty well having just been tuned and a few years of work bring it back from certain death. As I remember, it just needed a little electrical tlc…
However, on the last ride, it got stuck in second gear. The selector would not budge, and I rode it home and parked it. I pulled of the selector box, and don’t remember seeing anything too strange – but I might not know it if I did.
I guess the question is, what should I look for in the selector box? Is there something internally in the case that would cause these symptoms? Is there a fairly simple way to determine where the fault lies?
Sorry for the uninformed nature of this question – I’ve never gotten into this part of a bike before, and don’t know much about how it all works.
Tom
San Francisco
860gt stuck in 2nd...
- Colin Linz
- Diana
Sorry I can’t help with a specific answer, I just don’t know if they have a common problem in this area and I have never experienced it on my bike.
All I can do is explain what you will need to look for. I will assume that you have checked the shift mechanism and this is OK. Basically there could be two problems; the first could be that something is stopping the selector drum from turning. This may be related to the drum and its bearings, or the selectors freedom to move from side to side. Another possible cause could be that the selector is no longer in its correct position and cannot disengage the second gear dogs.
I have included some pics that may help my explanation make some sense.
The selector drum rotates and the selector forks are moved side to side by the channels cut into it, the selector forks have a peg that sits in the channels.
The selector forks slide across located by rods through the holes. The fork fits in a groove in the gear/dog clutch. When the drum moves the forks, the forks move the dogs into or out of engagement.
The above two pictures show the dogs and how they fit together. When the selector forks slide the gears together the dogs (the castellated areas on the sides) can engage. When the forks move them apart they disengage.
Colin Linz
Colin Linz
Tom,
The typical failure inside the gear selector box is that the return spring breaks. It is a Ducati specific part which many of the Bevel parts suppliers carry.
The photos of the gearbox and shift drum that Colin supplied are internal to the engine and require engine removal and disassembly in order to access.
If you remove the selector box, you can turn the shift drum with a screwdriver to check transmission function. It should turn easily. Rotate the rear wheel at the same time and you should be able to engage all five gears. If the shift drum doesn't turn, then you will have to remove the engine and split the cases to fix it.
Most likely its the spring inside the selector box.
Good luck,
Brian
Good luck,
Brian
shifter return spring- 75 860GT- can't find one!
well, I got the same problem...broken spring and I can't find a replacement...discontinued...and tried a few internet bevel places...no luck...and ideas out there...
rich
rich
sprung
the spring is THE SAME spring as what is used in current models
resurrecting thread
I finally took a look at the selector box for my 860, and found that it is binding. the spring was not broken, but skewed off the axis of the shaft and seemed to be binding.
Does anyone have a detailed pic of how the spring is supposed to be sitting? The haynes manual shows it fairly well, but another perspective might be helpful. Also, and hints on how to reseat the spring?
Tom
Tom
