Valve Stem Seals
Valve Stem Seals
Hi Guys! I have a 78 Darmah SD and am doing the desmo adjustments. Last time (2000 miles ago) I replaced the valve stem seals. What is the interval for these things? Should I replace them everytime? Thanks!
seals
If they start leaking replace them. They should last a *long* time. You could replace them at each valve adjust but it doesn;t seem required to do so.
So, I understand there is no chance to replace that o-ring without pulling out the valve !??
I guess I have to replace, because after 13 years of sleeping the engine smokes a little from the horizontal cylinder......
cheers
Joe
cheers
Joe
You are in doubt ?......ask a Kraut ;-)
Cheers from Germany
(Ducati 900 SD, Suzuki GSX-R 1000 K6, Suzuki GSX 1200 Inazuma)
Cheers from Germany
