Replacing cylinder sleeves
Posted: Thu Nov 02, 2006 1:32 pm
by sduc
I would like to replace the sleeves of my 750GT cylinders. Any tips or is it just a matter of the right temperature and the sleeves can be pushed out?!
Thanks in advance
Posted: Mon Nov 27, 2006 3:02 pm
by Geoff
Not done it myself, but the form is allegedly to place the barrel/ liner assembly upside down in the oven (send wife to off-licence for some more beer) leaving the area below the liner clear. Liner drops out when it gets to the right temperature. Replacement is the reverse, though I understand putting a weight on top of the liner ensures it stays fully engaged while cooling (otherwise apparently the top edge of the liner can stand proud of the barrel; if this happens you'll need to press it home when cool).
cheers
Geoff
Posted: Tue Nov 28, 2006 4:28 am
by sduc
Hi Goeff
Thanks a lot for your advice.
I will try it and let you know how it worked.
Beat
Posted: Fri Aug 29, 2008 2:10 pm
by cafe*racer
The oven trick does indeed work. Have a friend and some heavy duty gloves at the ready as you may need to help them get started or coax them all the way out once they get going. Seems to me like about 350-400F and about 20-30 minutes did the trick for me. Keep them moving until they are all the way out, getting a liner stuck half way is a real drag...literally.
Posted: Sat Jul 25, 2009 1:25 pm
by andygbsmith
A l,arge propane torch and 200oC works on Vincents so the same should work well on the Duke.
Andy
Posted: Sat Jul 25, 2009 2:48 pm
by mizike77
I have done it twice to ducati barrls.Its very very easy. Put it in the oven around 375 15-20 mins or so, take it out, hit the liner with a mallet then grab it with a glove or oven mitt and they came right out no problem. Putting new ones in is easier. Just heat up the barrel as before and put the new liners in the freezer. They pretty much fall in !!
