I've got the whobble ... !
Posted: Sat Oct 14, 2006 1:51 am
by dave
Hi There,
when i drive with my MHR'83 (complete stock) over 80KM/H and I take the hands of the handle bar, the front end starts whobbling ! :?
what can I do - check or fix :idea:
is this a common problem with beavels :?:
thanks for you help
:arrow: dave
Wobble
Posted: Wed Oct 18, 2006 9:59 am
by Craig in France
Hi Dave,
Well, handle bar wobble is classically caused by worn or loose head bearings. Other causes can be a worn tire, incorrect pressure, wheel out of balance, wheels out of alignment.
Craig in UK
P.s No, Bevels do NOT wobble.
wobbly bevel !!,
Posted: Wed Oct 18, 2006 1:56 pm
by wrinklygit
Sorry to dissagree Peter,but my old Darmah with leccy start & a battery the size of a small family house is rock steady at more than the legal speed limit,my money is on headrace problem.Does the wobble become worse or more apparent on deceleration,if so the fault is almost certainly due to play in headrace,Mike.
Posted: Fri Oct 20, 2006 3:58 am
by dave
I don't like to read this. :shock:
I thought they changed the frame manufacturers with the milles (as you sad they are really bad). that's what a ducati man told me. anyway.
i already took the bike apart. i saw that the front fork was leaking - needs new seals, tires are old too.
i will mount a steering damper maybe this helps as well.
the wooble feels stronger when decelarating. this was no fun driving - especially with a race bike. :roll:
the bike will be reassembled with a liegme fairing set and upsweep exhaust. i hope this is worth to do it.
i will take special care on front tires, wheel balance, bearings, front fork.
as the bike is now apart - could I strengthen the frame ? are there any plans where to add tubes ?
I will see if i can get it stable.
:arrow: dave
Posted: Sun Oct 22, 2006 3:17 am
by dave
Hi Peter,
thanks for your input !
I'll stick with the frame - for now. i was test driving another mhr 84 and the handling was ok. so - there is still some hope.
BTW - i found an 81 frame on ebay for 2250 Euro. too much for now. or what would be the price of such a frame ?
--> dave
Front end wobble
Posted: Tue Oct 24, 2006 3:37 pm
by Craig in France
Hi Dave,
With respect to Peter, I still don't think you should be getting wobble from your 83 MHR. I know the later frame has a reputation of not being so good, especially with the Mille engine, but for several years I had a MHR from the same year as yours and it never wobbled, at any speed, under braking, under acceleration, any time, ever ...
Until you've checked the basics, especially the condition of the head bearings, I wouldn't worry too much about major tasks like frame modifications.
If you're in the UK, talk to Tony Brancato, just outside Oxford (0)1865 891555, http://www.brancatoengineering.freeserve.co.uk/.
Craig in UK
Posted: Mon Apr 16, 2007 10:39 pm
by dave
Hi Boys and Girls,
after finishing my MHR. Fixing the front and rear.
NO MORE WHOBBLE ... so far. Runs straight without touching the handlebars.
And it runs :twisted: !! .... well next step are the carburators. Sometimes running to rich then to lean.
ciao dave
