FAQ - Swing Arm Shim source
Swing Arm Shims
McMaster Carr http://www.mcmaster.com has got the shims you will need. I bought some for mine to remove the kind of side movement you are seeing. While I don't have the exact part numbers, the sizes you are looking for are 30mm ID x 42mm OD. Build the stack as you see fit. I personally shot for about .005".
Ken Reece
Great resource
Post by Ken Reece »
Per Steve's suggestion, i bought a set of these shims from McMaster Carr in stainless steel for my 900ss. For under $20 dollars I was able to get and assortment that should last me through the next half dozen restoration projects I am sure. I bought three different sizes. They come in packs of ten.
Part#'s are:
.1 mm thick - 98089A240
.3 mm thick - 98089A321
1 mm thick - 98089A408
There are other sizes available.
Thanks Steve!!! :) :-D
