Magneto removal
If you need technical information or help with your non bevel drive Ducati single cylinder Cucciolo, 2-strokes, the overhead valve and scooter motors - post your FAQs, comments & questions here.
McMichael
Magneto removal
Post by McMichael »
I have a 1963 not sure of the model but it has a 125cc engine and while taking it apart for a rebuild, we couldn't get the magneto bolt to come out. is it a right or left handed thread and does it need a special tool to remove it?
magneto
http://www.shop.bevelheaven.com/detail.aspx?ID=518
Click the link above for the right tool..... measure the magneto it is either 55mm or 62mm, I have both tools in stock.
I can;t remember the thread for the bolt, someone else will chime in soon I bet, thanks.
McMichael
Post by McMichael »
is there a specail tool to hold the magneto to remove the nut holding it on
flywheel
the clutch holding tool can keep the engine from spinning - I stock those as well - click TOOLS to see that on my shopping cart
Return to “Single Cylinder Non Bevel Drive Engines > Cucciolo, Scooters, Overhead Valve, 2-Stroke”
