Hi
I'm rebuilding the rear Brembo master cylinder on my 1980 900SS .
There are 2 holes in the reservoir but only one seems to go through to the bore , the other seems to be blocked somehow - is this normal
or is it corroded - I've tried giving a gentle tap with a drift from the reservoir side but no joy
Any ideas. ?
Many thanks
Bob
1980 900SS rear master cylinder
chbevelbob
Re: 19080 900SS rear master cylinder
FULL STOP
Yes, there are 2 holes. One of them is 4 or 5 mm OD.
> The 2nd hole appears to be the same but isn't. This 2nd hole starts out as the same size but is not a through hole that size. At the bottom of this bore there is a very small hole drilled all the way through. maybe a half mm or so. I keep a piece of multi strand 16 gauge wire on my workbench, with the sheathing peeled back and all but 1 strand folded back out of the way.
I use this single strand of wire to push through this tiny pin hole while I am cleaning the master cylinder to make sure it is clear/open.
both front and rear brembo master cylinders have this same setup.
chbevelbob
Re: 1980 900SS rear master cylinder
Thanks Steve. Currently foghting the front sprocket
if you still have your chain on, this simple and inexpensive tool is absolutely fantastic to use loosening or tightening the front sprocket locknut.
https://store.bevelheaven.com/Tools/Sprocket-Jammer/
