Setting of PHF 32 AD/AS on a 750 GT
Posted: Wed Dec 25, 2024 6:50 am
I am am a bit confused about what could be a correct setting of jets, needles, etc. for PHF 32 AD/AS, as currently fitted on my 750 GT (OEM was Amal 30).
Asking the question because some of my fueling/ignition issues may be related, although I understand that I should beforehand check timing and possible air leaks.
The PHF 32 AD/AS were standard on the 750 Sport .
According to Falloon, the normal settings on the Sport are the following:
main jet - 125; idle jet - 70; slide - 70/2; needle jet - 265AB; needle SK17/2nd notch
The PHF 32 AD/AS were also fitted to the 860 GT with normal settings as follows:
main jet - 122; idle - 60; Slide - 70/2; Needle Jet – 265AB; Needle- K6/2nd notch.
Some users of PHF 32 AS/AD on their 750 GT however indicated on this forum that they used a 60/1 slide instead of 70/2 and also a 65 pilot jet instead of 70. No other indications however concerning the other parameters.
I understand that the Sport has higher compression pistons than the 750 GT, and that the 860 GT obviously has a larger volumetric capacity, so that it is difficult to guess from the data above what could be an adapted optimised setting for the 750 GT.
In the end, what could be the best (or at least a good) setting of all the parameters (main jet, idle jet, slide, needle jet, needle) for PHF 32 AD/AS on a 750 GT, or at least where to start from? (I do not know yet what is my current own setting, not having disassembled the carbs)
Any opinion is welcome!
