Wanted dimensions of these clutchgear parts
Does anyone know the dimensions of these distance pieces and bearing?
Part 28,34 and 30.
The distancepieces seems to be 25x35mm but I don't know the length of these.
The bearing Nr: 30 seems to be 25x52x15 (6205/C3 SKF) The other bearing Nr:33 is 25x47x12 (6005/C3 SKF)
And the shim, (Partnr:31) is 42x52x0.1mm
https://www.ducaticlassics.com/parts/10 ... and-clutch
https://ducatimeccanica.com/contents.html
I've found some bushes here......
https://www.aliexpress.com/item/1005005 ... e-home.0.0
I believe they are 25x35mm but what length?
This guy helped me...
https://www.kleinanzeigen.de/s-anzeige/ ... -306-16235
Nr28 is 11mm long and 34 is 9mm long both are 25x35mm
