Speedo drive
Posted: Sun Aug 04, 2024 10:43 am
by Ianhood
I have broken the ‘tang’ on my speedo drive. I have a new tang to replace it but how does the drive come apart?
Ian
Re: Speedo drive
Posted: Tue Aug 06, 2024 3:47 pm
you do not take anything apart - just remove the wire C clip from the back and slip off the old, then slip the new back on and reinstall that C clip. Now is a great time to fix the WHY it broke. Clean and lube your speedo drive and clean/lube your speedo cable............ And clean/lube your tacho cable while you are at it...
Re: Speedo drive
Posted: Thu Aug 08, 2024 3:07 am
by Ianhood
Many thanks, job done
