750 GT oil filter grubscrew
Posted: Tue Jun 04, 2024 7:41 am
@BevHevSteve
I note that you are proposing an interesting Oil Pump Entry Port Adapter made of improved metal pieces:
https://store.bevelheaven.com/Engine-Re ... t-Adapter/
On this occasion I just noticed that the grubscrew is missing under the crankcase of my 750 GT.
Maybe forgotten after the last oil change (not made by me) or fallen down on the road if not secured enough...
I would like to know what is the exact function of the grubscrew: is it to avoid rotation of the rubber receiving the end of the oil filter?
If missing, is there any risk that the rubber rotates and the oil flow to the pump is slowed down or stopped and should I stop riding my bike until a new grubscrew is installed?
Or may I consider that once installed after the last oil change the oil filter and rubber are sufficiently tightened in the right position?
Actually I already drove my bike beforehand without noting any issue and verifying through the glass window that oil comes up to the vertical head:
