No shims on swinging arm
Chasbmw
Post by Chasbmw »
I have just removed the swinging arm from my 73/74 GT.
There were no shims fitted, what clearance should I be aiming for and are the shims split between each side or are they fitted to one side only
The swinging arm pin came out with a bit of persuasion from a suitably sized spark plug socket and a lump hammer, lots of corrosion on the side of the swinging arm that did not have a grease nipple, if I drill and tap the swinging arm for a second nipple, should I go for a M6 size?
Charles
Re: No shims on swinging arm
the swing arm needs a shim on each side to keep the swing arm from grinding into the frame. I have no idea what tolerance is needed just not tight and not allowing for any side to side movement once installed. It doesn;t matter what size nipple you use just put it somewhere easy to get to and so it doesn;t interfere with anything.
Hi Charles: The parts manual shows three sizes: https://www.ducaticlassics.com/parts/75 ... and-shocks
My bet would be that a previous owner had the swing arm off and had trouble getting it back on with shims on both sides so gave up trying.
Good luck
Rick
Chasbmw
Post by Chasbmw »
Thanks guys, that very useful information I’ll see if I can measure what the clearance is before I order some shims.
Charles
