Steve,
do you stock po5 Brembo brake pistons,if you do,I would like to purchase 2 pairs?
Brake pistons
Re: Brake pistons
Yes, 05 pistons AND seal kits available, along with pin kits, bleed screws, banjo bolts and pads.....
pistons https://store.bevelheaven.com/Brake-Rel ... ston-size/
seals https://store.bevelheaven.com/Brake-Rel ... ston-size/
pin kits https://store.bevelheaven.com/Brake-Rel ... -F05-P105/
standard bleed screws https://store.bevelheaven.com/Brake-Rel ... 5-P32-etc/
or stainless bleed screws https://store.bevelheaven.com/Brake-Rel ... 5-P32-etc/
Galfer pads https://store.bevelheaven.com/Brake-Rel ... alfer-std/
(sorry about my initial reply, I misread 05 as 09.... The above links are all correct and in stock.
- 81mhr900ss
- 750 GT
Re: Brake pistons
Sorry Steve: When I read your first reply, I figured I'd help the OP find alternatives. I didn't look at your brake parts page as your reply suggested that you did not have these pistons.
Re: Brake pistons
Absolutely no issue here - was my mixup. Thanks for being oart of our forum..
