Darmah Handling
wrinklygit
- Mariana
Darmah Handling
Hello out there,as it's just started raining I thought I would spend some time & pass this tip on.Some time ago I came across an old post from Will Rogers re :Faster Darmah, one of Steve's suggestions was to drop the forks through the yokes to quicken up the steering.As I am using std handlebars (not clipons) the max amount I could let the stanchions thro' the yokes was 8mm & allow clearance between underside of bars & top of stanchion.If any of you haven't tried this you may be suprised at the results(another tip :allen keys make great tools for measuring or comparing heights,gaps etc )Have fun,ride safe,MIKE.
