Is this a Brembo P08 or a Bremo F08? What about replacement?
Posted: Tue Sep 27, 2005 8:49 am
by michielp
I have a brake problem. My 900 SS has a broken bleed nippel in the rear brake. See picture:
http://www.phys.uu.nl/~wwwgrnsl/seevinc ... uw_web.jpg
Is this a P08 or a F08?
Can I replace this caliper by the one on this website which has only one bleednippel instead of two?
http://www.shop.bevelheaven.com/SearchR ... egoryID=35
BREMBO
Posted: Fri Sep 30, 2005 3:31 pm
Hi Michael,
this is a BREMBO F08 right side caliper, it is a special 'shaved' or 'narrow' caliper used on bevel drive 900SS. It is a bit narrower and requires a thinner brake pad than a normal F08 caliper.
Click > http://www.shop.bevelheaven.com/detail.aspx?ID=275 for the caliper you need. Replacements are a bit different but mount and work exactly the same. They come complete with new pads, ready to drop in.
If you need replacement brake pads for your front calipers, click > http://www.shop.bevelheaven.com/detail.aspx?ID=173
If you would like, I can most likely remove that broken bleed screw for you, so you can keep the original style caliper. I do offer a brake repair/rebuild service. Contact me offlist for more info or give me a call.
