Removing stator from side cover
rightsideup
Post by rightsideup »
Having undone the 4 retaining bolts and removed the washers and triangular plates I've found that the original stator doesn't want to move.
Before I inflict untold damage I thought I'd ask the collective the best way to go about the job, puller, heat, witchcraft?
Thanks.
'74 Ducati 750GT | '78 MZ TS250/1 | '97 Honda VFR750
In the high latitudes of Finland, in the parching heat of Africa, under the most different operating conditions these motor-cycles run to the satisfaction of their owners.
Re: Removing stator from side cover
Heat the cover a bit, and try slamming the cover stator side down flat on a wood surface to jar it loose. Some stators are a tight fit in the cover and require coaxing to come out.
