860GT rear drum brake wheel hub bearing caps
Posted: Thu Dec 20, 2018 10:30 am
I really need help on this dilemma, and apologize if it has been covered in a previous post that I missed:
trying to remove "caps" on rear wheel hub bearings, per photos in the following Flickr link:
https://www.flickr.com/photos/124760992 ... 3339475701
The caps are not obvious to me in the parts manual, but are where items 0795.80.210 show in my manual (listed as WASHERS); mine are not washers, but caps around the outer bearing race on the bearings on both side of the hub. The only place where I see these caps mentioned is in my less-than-stellar Haynes manual, per the 4th pic in this group. It is mentioned that the caps can be prised off, which must happen to get to the bearings and remove/replace them. I did also buy the bearing removal tool from Steve, and will use that when I get the bearings exposed properly. After much effort and blue language, I am at a loss on how to get these stubborn dudes off without destroying either the hub or the cap itself. I haven't even gotten to the one on the cush drive side, and don't see any place to get leverage.
I could really use some advice on these two beasties: (Heat? Easing oil? Intense prayer?)
Thanks in advance.
Richard
Thanks in advance.
Richard
