Flywheel/clutch gear torque
Posted: Tue Jun 26, 2018 1:06 pm
I just wanna be sure:
Since the torque for securing the crankshaft nut holding the flywheel/clutch engagement gear is quite considerable, and since I have the clutch basket assembly off until I replace the disks and thus cannot use the clutch holding tool, I need to hold the crankshaft still while torqueing the crankshaft's flywheel nut on. I am assuming that, since I have the generator stator on the other side of the motor off at present, I can just hold the generator rotor nut with a 30mm socket and long lever, while I use an impact driver to set the flywheel nut into place. If I am missing something here, it is not obvious to me.
Any coments are welcome.
If any of you disagree with this approach, I could just re-install the clutch so that the clutch basket gear hooks up with the flywheel gear, I just don't want to break off a tooth on either piece.
I have acquired new shims for the flywheel side, but have yet to measure the old ones to compare with the new (still looking for my micrometer... likely buried under the Ducati guts strewn upon my workbench). That comes, of course, before torquing the nut on and bending over the tab washer since they go on behind said nut and tab washer.
Still looking for the right torque value for both the flywheel nut and the clutch nut.
Richard
Richard
