Darmah Front master cylinder
Andrew62
Post by Andrew62 »
Hi Guy's
I am looking for a front master cylinder for my 78 Darmah. It appears that these little puppies aren't made anymore and i dont seem to be able to find one i can rebuild. Any suggestions or idea's? What have other people been using in place of the brembo m/c?
Re: Darmah Front master cylinder
15mm REC type (rectangular reservoir) is great for your dual F08 Darmah. Why not rebuild the original MC? We do stock rebuild kits as well as the 15mm MC .....
Andrew62
Post by Andrew62 »
Hi Steve
Thanks for your reply and information. the problem is that it had a Honda master cylinder on it and i was wondering what people use now that brembo dont make that M/C anymore. Do i need to buy some other type/brand. Im looking for suggestions as to witch way i should go.
Yes a Brembo 15mm REC type
https://store.bevelheaven.com/Brake-Rel ... ont-Brake/
You can order it from Bevel Heaven with either a black lever or a silver lever....
Remember also to only use DOT 4 brake fluid such as MOTUL RBF600
