Wheely not difficult! GTS
Posted: Sat Feb 23, 2013 3:07 am
by bobnorton
For some obscure reason i can't put my rear wheel back in, it would appear that the cush drive is holding off and not leaving enough room, no parts replaced so its just me , or have i missed something?.
Re: Wheely not difficult! GTS
Posted: Sat Feb 23, 2013 5:12 pm
by wdietz186
Bob, Take the rubber spider thingy back out and flip it. The o ring section in the center is holding it off,should lay flat against the wheel side of the cush setup I think.This is from distant memory.Haven't had one apart in years but I remember having the same problem and flipping the rubber around fixed it.
Posted: Sun Feb 24, 2013 3:05 am
by bobnorton
Thanks , I must be getting old.
Posted: Fri Mar 08, 2013 2:37 am
by saraceno59
I had my rear wheel out recently, to replace the bearings. The problem that i had was the rubber behind the sproket carier, i had to grease both sides to get it back in place. Once i did that i got the wheel back in, not very easily but with a little patience i have made it!
