Wanted: Front signal threaded hollow rods
I need a pair of the hollow threaded rods that the front signals mount on. The ones that would be used if you had the wire headlight mounts on a 750, 860, or 900. Basically open on both ends, threaded all the way. Have had no luck at hardware stores, etc. Anyone has a pair lying around let me know. PM or email confusa(at)speakeasy(dot)net.
Re: Wanted: Front signal threaded hollow rods
You need to specify if threads are to fit APRILIA or CEV turn signals in order to get what you want.
Ahh, didn't know it made a difference. Mine are Aprilia.
BevHevSteve wrote:You need to specify if threads are to fit APRILIA or CEV turn signals in order to get what you want.
