I am new to the group and new to Ducati ownership- recently bought a 78 Darmah.
The previous owner removed the starter, solenoid, 32 carbs and airboxes off early in the bike's life and bagged them up. They came with the purchase and I want to put the starter back on. I am having a hard time locating where the solenoid and the ground strap are supposed to be mounted though. There is a pair of mounting holes on the left side of the frame back by the battery that are spaced too far apart for the solenoid, and I cannot find any other mounting locations that make sense. Any one have a good photo or description that could help me out?
I have checked the parts manual, owner's manual and maintenance manual for a drawing or description to no avail...
Thanks for any help-
Best-
Matt
Newbie help- Darmah component location
Re: Newbie help- Darmah component location
Matt - those 2 holes on the left side of the frame, the side frame PLATE, are where the stock solenoid is bolted on sideways. I would guess that you have a non original solenoid then if it doesn't fit there. Just drill a hole in the bracket to the solenoid you have so the holes line up and fit it on there..... That's what I would do. I just had a look at one of my totally stock darmah's here at the shop to verify the above and what we talked about yesterday.
Thanks Steve.
How about the ground strap?
I will try and shoot some photos tonight and figure out how to get them posted...
Best-
Matt
Best-
Matt
There are 2 large posts with 2 large diameter wires going to the solenoid. You have the battery {+} to one solenoid post, other solenoid post to Starter. There is a small yellow wire that will clip onto a post between them from the harness.
Hi Matt,navyguy wrote: Any one have a good photo ...
Like wot Steve said, and here's a photo that may help to clear up any remaining confusion:
If it was me, I wouldn't refit the old solenoid. Better to go get a new one. They are prone to serious internal corrosion. I guess Joe Lucas never intended that they should be mounted 6 inches above the road on a motorbike
http://www.ebay.co.uk/itm/Land-Rover-Se ... 230557586b
Figured it out- the back of the ID plate- I was looking on the frame tube.
Thanks for the help Steve!
Best-
Matt
Best-
Matt
