860GT with a heavy clutch
eternally_troubled
Post by eternally_troubled »
I've read Steve's article on the clutch actuating linkage and I suspect that my 860GT may be a prime candidate for needing its linkage cleaning and greasing. It's rather heavy to operate and I'm sure I can feel a slight grinding...
Just a quick question - I assume that the adjuster can be accessed through one of the small covers in the left-hand side case, if so, can I push the rods/balls/etc out without removing the whole left-hand side, or is this an impossible task?
I don't mind taking the left-hand side off, I'd just rather not if I don't have too...
Pull the little cover on the left side,remove the locknut and adjuster and push the rods,rollers,and balls out with a thin rod,after removing the right side shifter box.
eternally_troubled
That's what I want to hear.
Thanks for the info, I'll get back to you if I manage to fix it!
Be sure to check diameters of the different rods and balls.
Keep manual on Your side, easy to get this wrong.
cu
joseph
