I feel like I am in need of a remedial version of this forum. I have the Dyna S and a degree wheel, and all the instructions a boy could want.
I can't get the plug out of the case to acess the crankshaft!
The plug has been severely worn prior to my reciept of the bike. I feel like I had my first best chance to remove it last night when I had a large allen wrench inserted and when I gave it a good tug instead of coming loose it stripped out a bit more. Now I am feeling pretty stumped but am trying to come up with workable ideas.
I suspect I will end up taking the side of the engine off and having it proffessionally removed and then I will need to find a new plug.
So, any ideas, guidance etc is welcome.
I have great compression, clean carbs, new coils, a new fuse block, rebuilt brakes, all the lights work, the tires are new, the bike is starting to look good, now if I can get this ignition in I am hoping to be able to ride it around the block.
Robin 750GT
feeling really dense
new owner of 1974 750GT
Even with the right size allen wrench the hex in them is sloppy. You could try strip of thin aluminum across the face of the wrench and hammer it into the plug.A piece of beer or soda can would do.OR if you have some valve grinding compound you could coat the end of the wrench and put it in the plug. You need to support the wrench so you don't put any side load on it while you are turning it. The beat tool would be an allen socket and a short extension so you can support it.Harbor Freight sells a set of metric allen sockets pretty cheap and they aren't too bad. If all that fails a fairly large dull[ish] chisel and a heavy hammer on the outer 1/3 of the face of the plug at about a 30 deg. angle in the counterclockwise direction will usually get them loose but you run the risk of maring the primary[Very $$$$$$] cover plus you will have to replace the plug but you were going to do that anyway right?
welshmally
- Diana
http://shop.bevelheaven.com/detail.aspx?ID=782
We stock these brass plugs that have a magnet inside - and sell loads of them because they work.
