I was so foolish to hope to avoid this issue, but isn't the case.
But I am a bevel man, so madness is quite normal for me.
This is my sproket carrier
and this is a badly ovalized hole
And obviously the sprocket bearings are gone.
Before to undo the wheel I got spare bearings for the wheel axe, but not for the sprocket, so now I have plenty of time to think a good solution, since I don't think I'll be able to have the bearings before 10 days.
I have read the posts about this topic in the forum, but I'm quite unwilling to drill larger holes and put oversized bolts.
The holes are about 8.2 mm x 9 in the side of wear and obviously have got a conic shape. What about trying to use inserts similar to Helicoils? The hole is too large for put an M8 Helicoil, but maybe it's possible to find something that can be made fit.
The original cush drive rubber seems in quite good conditions and I have a new spare part for F1 and Pantah 0795.80.230 that should be compatible, do you know if I can mount it without problems or do you think it's better to use the original one?
One more problem, a bolt fixing the cush drive house to the rim is broken.
I'm thinking to drill and extract it . Do you know the length of the bolt? I'm not very keen of trying to remove another, that can broke as well, until I'll be able to extract this one, knowing a little more about it will facilitate my task.
Yes, this is working at an old bevel
Giovanni
