I thought I would describe my adventures with fork oil changes on a '77 900ss.
I initially tried 10W (Castrol synthetic) as suggested on the shop here (albeit Motul, not Castrol) for average weight riders (I'm under 150lb, so that's me, or so I thought!).
It turned the front end into an uncontrolled pogo stick, with virtully no noticeable damping and massive dive under even moderate braking.
So I wrote it off as expensive flushing oil, & replaced it with semi-synthetic 20W. It now seems better, certainly not overly stiff - yet to be ridden far/fast though.
Can't see how anyone could be OK with 10W, let alone 5W (water?). Might be right for modern forks, but certainly not for old Marzocchis.
Anyone had different experience?
Front forks
sounds like your springs are toast, and/or you didn;t put the correct amount of fluid in your forks [not enough].
notanumber
- Mariana
Thanks for your comments. To me it seems a damping issue, there's no excessive static 'sag' - and no problems before changing the oil. I used 230cc in each leg. How would the springs get toasted anyway? The bike has only covered 15k miles, 'never raced nor rallied' as they say.
I've since noted that the Stephen Eke book also states that 20W is the standard oil.
forks
Yeah that is strange. I use 10W in mine and they work fine. There was an issue with 2 different publications giving 2 different amounts. From memory one said 230 and one said 270ml. I do remember I went with the higher figure. More is better right?????? Point I`m trying to make is there is none of the issues you speak of. I did however invest in some progressive fork springs and was very happy with the result. They were a very reasonably priced mod considering the improvement. Keep wondering about investing in some of those emulator jiggers I read about....................but the kids keep rail roading the funds on frivilous stuff like food and education. Trouble with this generation, no sense of priorities................
Greetings,
Since I am a new poster and I have asked some questions then I should reciprocate. The aluminium damper pistons and their associated nylon rings can wear. I used to have mine custom made to each stanchion by a local machine shop. Very cheap and very effective.
There should be no reason to use heavier oil unless you are a big guy and are using stronger springs to compensate for your weight.
I have always used 250cc in each leg and 280cc in offset axle legs.
cheers
cheers
Sir Duke Sam
Hi Notaumber
I have just had the same thing happen to me as well
Removed the legs drained all the fluid gave everything a clean and add 190ml of 10w , bled the forks by pushing them up and down to rid of any air bla bla and now I have the same as you pogo stick like feel its horrible.
Before the strip down everything worked nice and smooth, I added another 60ml but this made no difference.
What went wrong ?
What went wrong ?
notanumber
- Mariana
Hi Sir Duke
Reassuring to hear your identical experience. I'd suggest nothing went wrong - 10W is simply the wrong grade of oil.
I now realise the original recommendations were indeed significantly heavier. As well as the Eke book, the 1977 Haynes manual also states Agip OSO 25 (which I understand is about 25W) or 'SAE 30 fork oil'.
Not sure where to get SAE 30 to experiment with, but the point is that fork oil in those days, as with engine oil, was generally thicker than modern products. Other old stuff I found in my garage for example, Morris ML7, is 20W.
Putoline 20W seems to work OK.
Sir Duke Sam
