1979 SSD frame footpeg mounts
Posted: Tue Jul 05, 2011 7:10 pm
by mdal
Hi All
My frame has been altered along the way by someone to move the footpegs further back. The old mounting bosses have been cut off and a new mount fabricated. In the quest for originality I have removed the new additions and now want to go back to original. I can see where the old mounts were located by the ground off welds. Could someone please measure their mounts and tell me:-
1. The dimensions of the mounts
2. How far they protrude out past the frame.
Thanks Mark
See photos
Having trouble with photos
Posted: Tue Jul 05, 2011 7:18 pm
by mdal
Posted: Wed Jul 06, 2011 1:45 am
by mizike77
The toothed circle under the swingarm pivot is the factory peg mount. Not sure what the cut off welds are from...
Posted: Wed Jul 06, 2011 2:04 am
by Craig in France
Hi Mark,
3 photos below of what I think you want. In which case, it's 30mm long, 20mm OD. (Sorry, didn't measure the ID but I guess it will be whatever your pegs need ! )
HTH, but if you need more, let me know.
Posted: Wed Jul 06, 2011 2:27 am
by Craig in France
mizike77 wrote:The toothed circle under the swingarm pivot is the factory peg mount.
You might reasonably think so, but that's not actually the case. While you find this knurled fitting on early SSDs like Mike's, it wasn't in fact used for mounting the pegs - or, indeed, anything else
(However, I s'pose it WAS used on the SD, tho' - ?)
You can see it here 'Not in Use' on my SSD.
Posted: Wed Jul 06, 2011 1:01 pm
by gioto3
Hi Mark
These are two pics of my footpeg mounts
At the moment I don't have more detailed pics, They seems identical to Craig ones.
If you need any measurements or detailed pics just let me know.
Giovanni
Posted: Wed Jul 06, 2011 2:52 pm
by mdal
Thanks Craig and Giovanni
Can I assume the mount protrudes past the frame by approximately 10mm.
Could you please confirm. See attached drawing.
Mark
https://picasaweb.google.com/1173514082 ... directlink
Posted: Wed Jul 06, 2011 4:44 pm
by mizike77
I thought it was an SD....my mistake!!!
Posted: Thu Jul 07, 2011 12:00 am
by gioto3
Hi Mark,
the total length of the piece is 32 mm and in my bike it protrudes 12 mm from the frame and is oriented on the other side respect to your drawing, have a look at the pic.
Giovanni
Posted: Thu Jul 07, 2011 12:52 am
by mdal
Giovanni
Thanks for that. I have mounts made and now can go ahead and complete welding in position.
Mark
