Big end bearings s/n
hashashan
Post by hashashan »
Hello,
does anyone know the serial number of the big end bearings of a 78 darmah ?
I don't think they are available separately. Come with the bigend-set.
The rollers are standard items, but I think the cage is special.
cu
hashashan
Post by hashashan »
ahh no problems with that. i just want to see how much they cost here. so i need the serial number of the bearings .. rollers+cage. I just couldn't fins this anywhere.
http://cgi.ebay.com/ducati-bevel-twin-7 ... 500wt_1156
this price makes any sense? 400$ for bearings?
The problem you will run into is if the bearings are worn,the crankpin will be too, along with the ID of the rods that is why the parts are supplied as a set. The rollers themselves don't usually wear much it's the pin and rods that wear because they are the softer pieces.
As the seller says : IF the rods aren't damaged, you can use this set.
Don't know about the diameters though : this set is the stepped 36-38.
Some Darmahs had 36 but others had 38 mm.
cu
