widecase? narrowcase?
Posted: Mon Mar 22, 2004 11:59 am
by chris m
hi.
i own a condor a350 with a ducati single.
is this a wide or narrow case model?
how can i tell the difference?
thanks.
/chris
narrow or wide case?
Posted: Mon Mar 22, 2004 12:40 pm
by Eldert
Hi Chris
A Conder uses a widecase engine
the 2 rear engine mountings are 205 mm wide
on a narrow case engine the mountings are only 70 or 80 mm wide
the Condor engine uses a different gearbox as a Ducati and has
screw aduster type rocker arms for easy of maintenance
Eldert
Re: narrow or wide case?
Posted: Tue Mar 23, 2004 12:21 pm
by Guest
Eldert wrote: A Conder uses a widecase engine
Thank you very much, Eldert.
Nothing is wrong with my Condor*, and I've got an opportunity to buy a 350 scrambler narrowcase parts bike. Am I likely to find much parts interchange, or are they totally different animals?
Thanks again.
/chris
* actually, there is something wrong: sometimes after shifting into 3rd gear, the selector lever doesn't return all the way to the middle position. I can't get into 4th gear without "helping" the shift lever back to the middle.
when i try shifting manually (with the motor stopped) i get a click going into 3rd, but no click when i release the lever. 4th is unavailable until i lift the lever and get the next click. only then can i push down and find 4th gear.
Posted: Tue Mar 23, 2004 11:17 pm
by Eldert
Hi Chris
As for the shifting problems there is a screw under the shifting lever
you can adjust. that screw has a excenter on the other end and let you
play with with the spring inside the selector box
if that dont help the spring got to weak over the years and you have
to fit a new one.
i dont think 350 narrowcase scramblers ever left the factory
if it is one very few parts do interchange but if it is cheap buy it
anyway. you can allways swap narrowcase part for widecase parts
with someone
Eldert
Posted: Wed Mar 24, 2004 7:58 am
by Guest
Eldert wrote:Hi Chris
to fit a new one.
Huh, great! the spring was one of the first things i planned to grab from the parts bike (after the side stand). Thanks so much for the tip.
Eldert wrote:i dont think 350 narrowcase scramblers ever left the factory
with someone
Eldert
Hmmm... so perhaps the parts bike owner is mistaken? i can't quite make out the details in the pictures i have, perhaps you can comment:
http://logsoft.com/chris/parts/
Thank you so much!
/chris
Narrowcase allright
Posted: Wed Mar 24, 2004 8:43 am
by Eldert
Hi Chris
This bike is a narrowcase. you can tell if it is a 250 or 350 by counting the
fins of the cilinder . a 250 has 8 fins and a 350 has 9 fins
Eldert
