Brake Switch
Posted: Fri Oct 22, 2010 1:29 am
by Gum
73 Sport rear brake switch, whats the go mine is on all the time. Can they be fixed, thanks Gum
Posted: Fri Oct 22, 2010 7:58 am
easy enough to figure out if you just always have pressure in the system... Crack a bleed screw with the key on, did the light go out?
If you are talking about the rear brake the switch needs to be cleaned.
Tar
Posted: Fri Oct 22, 2010 4:48 pm
by Gum
I will take it off and give it a good clean, lets hope that fixes it.
Thanks Gum
Done
Posted: Sat Oct 23, 2010 4:35 am
by Gum
Had to pull it apart and fit an O ring, the rubber inside was worn, all good now. Thanks Gum
