Is detergent an issue when changing to Castrol DD 50?
gabby
Post by gabby »
Hello. Without wishing to start off with any sort of major oil discussion here... I'm aware of the negative comments about using a detergent oil in a bevel engine. Or should I say in a dirty engine where it's been said it can loosen deposits with bad results. So, if I was using Shell HD50, which I now can't get, and change to DD 50, should I be concerned? This states it's got detergent. It's a 750GT and done only a few thou since rebuild. Thanks, G
rwhc80
Post by rwhc80 »
G"day Gabby,
Boy, glad you clarified your first line, cause oil is such a such a contentious issue.
Castrol CRB50 was recommended to me years ago by a Ducati mechanic who swore by it. The DD50 Tection is the replacement for that oil as it was discontinued a few years ago. Amongst my group of friends who own old bevels and use the DD50, none of us have had any problems at all, so I would say go for it.
Others may disagree, but I will stick with what has worked for me !
Rick
Use whatever you want to as long as it carries an SG rating
gabby
Post by gabby »
Thanks guys for the replies. It sounds safe - must tell myself to stop being paranoid about the old girl.
big phil
Post by big phil »
BevHevSteve wrote:Use whatever you want to as long as it carries an SG rating
hi, whats an S G rating?
big phil wrote:hi, whats an SG rating?
Hi Big Phil,
It's the API system of rating the properties of engine oils, API being the American Petroleum Institute. The 'S' tells you it's an oil designed for use in petrol engines, as opposed to diesels. The 'G' is, in origin, a time-related designation: the letter changes whenever a new standard is required to reflect changes in oil technology. The first standard was 'A' back in the 1930s and we're now on 'N'.
What this means in practice is that, by looking at the rating printed on the oil tin, you can determine things like zinc content. Zinc is something that our engines need, but which newer oils don't have 'cos it does nasty things to catalytic converters. Hence Steve's support for 'older' ('obselete' is what API call them!) SG rated oils. API considers SG oils to be suitable for 1993 and older engines.
Lots of info on Tinternet; for example, go
http://www.aa1car.com/library/api_motor ... ations.htm
All bevel drives........ SG rated a must.
Steve Foster
Post by Steve Foster »
The Castrol Edge Sport 25W-50 has an SG rating if you're keen on using Castrol.
http://www.castroledge.com.au/downloads ... 200601.pdf
The monograde Castrol Tection DD 50 that has been mentioned has an API SF petrol rating.
http://www.tds.castrol.com.au/pdf/5028_ ... 200611.pdf
1974 Ducati 750 GT
Peter Mille wrote:Why only SG rated oil? <snip>
Hi Peter,
This is what I understand ...
1. Yes, ZDD (aka ZDP or ZDDP)* is generally considered a 'Good Thing' for our kind of valve gear. There is test evidence that it helps reduce wear and 'scuff' (as it's called). That said, it should only really come into play in extreme circumstances; so, if you change your oil frequently anyway, it probably doesn't matter too much.
2. The ZDP content of a SG oil is 1200-1500 parts per million. In an SJ oil, it's 1000 ppm. So not THAT different. It's SM oils that you most want to avoid: the ZDP content in these is 600 ppm. And there does seem to be evidence that valve train damage can occur at this level ..
3. The other thing about SJ oils is that they contain more molybdenum disulphide than SG oils. Molybdenum disulphide acts as a 'friction modifier', i.e. it reduces friction between components, particularly at high temperatures such as you get in car turbos. Another effect it can have is to improve fuel consumption. So both effects should be 'Good Things'.
Unfortunately, it can also cause problems with wet clutches, causing slip. That said, the recommended oil for my Laverda 750 Formula - roller bearing crank, sliding valves, wet clutch - is a 20-60, SJ, synthetic ...
4. Just beware the 'Total Backwards Compatibilty' claims of the API. It has been claimed that the old engines that were used to test the newer grades of oil were low performance, i.e. the oils were not subjected to rigorous working conditions.
* Zinc Dialkyl Dithio Phosphate
shenglu
Post by shenglu »
"S" to tell you, it is designed to use gasoline engine oil, opposed to diesel. The "G", originated in a specified time-related: Whenever a new standard is necessary to reflect changes in technology and changes in oil-letter.
