Cylinder Head Interchange Question
Posted: Tue Sep 21, 2010 3:09 pm
Can you put desmo SD heads on a valve spring GT engine?
Ducati Maintenance, Preservation & Restoration
https://forum.bevelheaven.com/~BB/phpBB3/
https://forum.bevelheaven.com/~BB/phpBB3/viewtopic.php?t=3165
Thanks.Jon Pegler wrote:Only if you are very proficient in the use of machine tools.
You have to bore a hole for the closing rocker spindle, very accurately.
Even then, the spacing of the inlet manifold studs would preclude fitting 40mm carbs.
In short, the answer is no, unless you have access to a well equipped workshop.
