Hi from the UK
chas b
Hi from the UK
Post by chas b »
Hi all,
been lurking for ages and thought it was time I registered.
I've got a 900ss special which I've owned since 1985. I made many changes as you can see ( purists,look away!) and covered 45000 miles on the bike until retiring it early 1991.
I'm now doing a little bit of restoration starting with the brakes which have been completely overhauled with new seals and pistons. More work will be done as time and money allow.
Chas.
GTS Laz
Post by GTS Laz »
hey ,
chas you bike is perfect dont do a thing to it i do like it asn it is.chain clearence on tyre is a problem,a huge amount of work.but can be done.
laz.
ps i am in the UK.
welcome aboard, thanks for posting your photos
GTS Laz
Re: Hi from the UK
Post by GTS Laz »
Hi,
Can any one help.My 900gts has a problem on start up.It runs for a shrt while and then dies .Plugs foul up.This happens on very short runs as well.Any ideas of type of plug i can use.I am using NGK B7HS 5110.
thanks
laz
Re: Hi from the UK
GTs Laz - the first thing you need to do is start a new topic for your question in the engine section and not sidetrack this topic. Please do so ASAP and the email me so I will then delete this out from here . Thanks.
