Trick for removing bolt in the end of the damper rod?
confusa
Post by confusa »
So I got one fork on my GT rebuilt with little issue. The other, the bolt that goes in the very end of the damper rod just spins and spins which I am assuming means it is turning inside the fork leg. Is there a trick to stopping it internally so that I can get the bolt out? My old Yamaha had a tool that you placed inside the fork for that purpose. 38mm Ceriani if it makes a difference.
Jon
Post by Jon »
I have found pushing a broom handle up te centre of the fork tube to press damper rod against the end of the stanchion works most times.
cheers
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
Many times a quick burp with an impact gun[air or electric] will suprise the bolt out before the damper rod spins.
Yep - use an impact gun and do this step before taking springs out etc
