Hi folks,I have a1980 darmah I wish to change the spragg bearing,I beleive the are like a cam belt on a car if you dont know how old it is then you should change it to be on the safe side,my problem is locating one here in the UK at the right price,so does any one have the spec and serial number so that i can locate one.. much obliged for any help or suggestion's, the one that i have taken out has no referance on it,
Cheers Artfull dodger
spragg bearing
artfulldodger
spragg bearing
ride em while you can
http://shop.bevelheaven.com/detail.aspx?ID=67 why not support this forum and buy one here - choose FLAT RATE ENVELOPE INTERNATIONAL PRIORITY for less than $20 or first class for around $10 to ship it to you. At $137 that is less than half the cost of what we sold them for less than 3 years ago. If you get a mate to buy 1 at the same time you can get the 2nd for $99 which brings the per bearing cost down quite a bit.
