Imola 73 Replica..coils
DesmoSS
Post by DesmoSS »
I have placed an ignition DYNA-S.
The motorcycle is prepared for ignited double..but I do not know that type of coils and the connection is the suitable ones.
Now it is with coils PVL of 12V,the motorcycle works but it fails much.
We have worked in the carburetion having tried to look for a solution,in the end we thought that it is an ignition failure.
I have thought to in series place 2 coils of 6V for each cylinder,but before it would want to me to ask for aid here.
Somebody has knowledge of some motorcycle that has ignition double and it can say to qie type to me of ignition has???
P.D.they excuse my terrible English.
hello,
I can get you set up with a pair of dual output DYNA coils that you can hook up to your DYNA S system, and of course you would need 2 of the DYNA wire kits.
the dual output coils are the same price as the single output coils I have listed on the site already. For a streetbike I suggest you use the black 5 ohm coils, if a race bike [racing speeds all the time ont he track] then go for the green 3 ohm coils.
order these http://shop.bevelheaven.com/detail.aspx?ID=820 $149.95 + $16.50 for 1 set of coils + wires, then order an additional set of wires. Follow up immediately with an email telling me to get you the DUAL OUTPUT coils and I will do so for you.
