Steering head bearing replacement
I recently installed new bearings in the steering head of my Darmah. I used a bicycle headset press to set the races in. My question is this, are the races supposed to recess into the headstock a little or are the races set flush with the top and bottom of the headstock? Something doesnt seem to be right with my front end. I also changed the fork oil before I saw steves recommendation for type and level, and I put too thin oil in there.
The bore for the races in the frame should have a little step where the race seats.The races may stand a little proud of the top of the tube or not.As long as the race is seated you should be ok.Even if the race is a bit below the top of the bore you should have enough clearance to get the head bearings adjusted properly.Be sure and check them after you have ridden it a while as things can settle and the adjustment will loosen slightly.
make sure the things are seated fully in the recess..... That is how you install them. Then all the other advice you have rec'd above is also valid.
