Can someone post how the engine breather hoses attach to and from the oil catch tank on a 76 SS ,where does the out hose go to ?
76 SS oil catch tank
cafe*racer
- SSD900 Darmah
Martin, the parts catalogue says the vent hose L=440. I assume that is mm, which is a little less than 16 inches. Look at the photo on pg. 69, top right, of Original Ducati Sport & Super Sport (black cover). Looks like the vent hose routed over the cam support to me, but the only photo I could find that bears this out. Jordan
MartinMille BANNED
- BANNED
nottonight68
- BLABBERMOUTH
MartinMille BANNED
- BANNED
cafe*racer
- SSD900 Darmah
My 77 SS has a "BreatherBox" located under the rear of the seat and the exit hose was vented to the front cyl. air filter box.In the end was a cute little flapper valve to try to keep the engine from inhaling too deeply and pressurizing the crankcases when the pistons are near the bottom of their strokes. In normal street usage an open vent causes no problem but at extended high revs it can push a fair amount of oil out the breather.When I started racing mine I put a reed valve in so the cases could only exhale and in 20+ yrs. of racing it I never had more than a few teaspoons of oil in the catch tank.
breather
On my old 76 GTS I just ran the hose up under the tank and cable tied a rag over the end of the hose. It`s never spilled a drop in many a year. Hey, sounds rough as guts I know but seems to work a treat. Mind you the old girl don`t see red line too often and the rings are tight so no blow by to speak of. Cheap and cheerful. I do however change the rag regularly(maybe once a year) and I do use high quality rag. I think hooking it up to a breather box gives negative pressure in the crank cases which in turn will help inhibit oil leaks elsewhere.
