Hi all.
Just started a strip down of my Darmah's carbs and noticed a small groove in the top of each float. It appears to be where the tickler rod bears against the float. Is this groove supposed to be there? or do I need a new set of floats.
Rich
Dellorto 40 Float Question
If it looks worn then replace it. If it is wearing thin then eventually it will get a hole and cause problems.
r1ch4rdb
Cheers Steve,
The grooves appear to be similar in size but rough edged so i guess safer to replace while its in bits.
Thanks again
Rich
Thanks again
Rich
