There used to be a Comparison list online but the link is dead now
Below is that missing list
Headlights
Darmah headlight: a little cheaper as BMW H4 headlight glass /seal /rim.
Handlebars, switchgear
Bevel Drive 900 models (Darmah, Darmah SS, SS) with Nippon-Denso handle bar switchgear is the same as on similar year GS series Suzuki’s.
Battery
Darmah battery - (same dimensions as fitted to Reliant Robin) Varta 53030 12v 30 AH 180A - Sears Die-hard Gold, garden tractor battery, 96135, Group U1, 325 CCA.
Key blanks
For the Darmah: Taylor blank # F69H or F69F. For 1980 900SS: ILCO (made in Canada) F91H/F69H (Original key says "BG" on the rubber part and "H3" stamped on the key itself
Starter system
Darmah starter motor brushes: (BMW?) part number SBR 5830
Hailwood replica (Mille) starter motor - Suzuki GS400-425-450 or 500 models.
Bevel-twins sprag clutch: Rover car part number is 22A716. Please note that the outside diameter of the cage that holds the segments together needs to be turned down to 65.5mm.
Bevel-twins sprag clutch: Rover car part number is 22A716 and the outside diameter of the cage that holds the segments together needs to be turned down to 65.5mm. There is a dealer in England who can carry out this work: Alf's, 100 Dominion Road, Worthing, West Sussex BN14 8JP England. Phone: 01903 200948 - Fax: 01903 210547 Email: [email protected]
Clutch
Bevel friction plates - Suzuki GSF400
Comparison list for Bevels , what fits what
MartinMille BANNED
- BANNED
