Early 60's 250 Frame Inquire
Posted: Tue Feb 03, 2009 4:57 pm
by cmborn
I am in the process of restoring a 250 single. The forks indicate 1963. The question relates to the frame and previous owner modifications. Is the cross member correct or does it need to be removed? What's up with the welded bar across the joint?
[/img]
Posted: Tue Feb 03, 2009 5:29 pm
by wdietz186
I'm no expert on singles but that looks to be a rear loop that has been welded onto a frame that was either modified or wrecked. It appears to have a crack forming in the lower right side of the joint too! The bars are a definite bodge. I would have the welding redone by a professional and clean up the bird poops holding the rear loop.It's kind of a shame you've painted it already but you don't want to have the seat break loose while you are riding Do you?
Posted: Tue Feb 03, 2009 6:59 pm
by Macdesmo
Wdietz is right .The front seat mounts are wrong too. There should be a hole in the rear loop for the tailight wiring to pass through but not as many as in yours. I can't see in the photo whether you have toolbox mounts. Also, I can't see if the rear guard mounts are correct either. I can't remember what the mounts for the original regulator were like. Best advice is to find out what model it is and have a look at one if you can. I would be looking around for a original frame if you are going to restore to original. The parts book will give you an idea. All the best.
Posted: Tue Feb 03, 2009 11:58 pm
by Eldert
this frame had a crossbar welded over the shockmounts originally .
that makes this frame a scrambler frame
Eldert
Posted: Wed Feb 04, 2009 7:38 pm
by cmborn
Thank you for your comments and advice. I had the frame media blasted and oxide coated just to see what was under the powder coat. I also noticed that the front lower tube was straightened in a rough manner. The media removed the bondo and revealed the compromise. I hope the unknown previous owner survived the impact...
Since I have most other parts...let the search begin. Any ideas on where to look for a Diana or Monza frame would be welcomed!
Chris
Posted: Mon Feb 09, 2009 1:49 am
by Aussiess
Try Phil Hitchcock at road and race- check Steves links for contacts
250 single frame
Posted: Sun Feb 15, 2009 2:30 am
by Bob Lancastle
Hi,
I'm in the process of restoring a Mach 1.
email me on
[email protected] and ill send you some pics
Bob
