fork springs
- Colin Linz
- Diana
fork springs
I’m hoping you guys can help me. I’m looking for some replacement springs for my Marzocchi forks, something a bit heavier and preferably a linear rate around .85kg/mm. Also does anyone no if any of the race tech emulators fit these forks?
Colin Linz
Colin Linz
forkin springs
Hey Colin,
really you must go see my store..... I have the perfect fork spring kit for out 38mm bevel drive forks, dual spring rate, have installed many of them on customer bikes, I developed the fork spring kits as well as shocks with WORKS PERFORMANCE engineers over the last several years, I believe we have reached perfection at this point, well, at least a good as we can get on these beasts.
Go to http://BevelHeaven.com and click eStore for all your restoration needs.
- Colin Linz
- Diana
Thanks Steve, I will keep them in mind. I was hoping someone had found one of Race Techs, Gold Valve Emulators that will fit in the Forks. Generally I prefer a linear rate spring over a duel rate spring; however if I have to retain the velocity squared type damping system I will give the duel rates a try.
Colin Linz
Colin Linz
