F1 / TT2 Side Stand
mayoreric
F1 / TT2 Side Stand
Post by mayoreric »
I am taking a delivery of an F1 (hurry up Steve!) that has had its frame cut where the center stand would normally mount. Does anyone have experience fitting a side stand to a TT2 or an F1 similarly modified? I was thinking of fabricating a plate to bolt to the engine case on the RH side and welding a side stand to the plate.
What kind of side stand has been adapted for this purpose? Any tips or tricks?
Eric W.
91 851
85 750 F1
80 Morini 500W
73 Benelli 250SS
67 Trail 90
97 F650 ST
Albuquerque, NM
alla'azurra side stands supposedly bolt up
[i'm pushing the bike as fast as I can eric] :roll:
mayoreric
Sidestand
Post by mayoreric »
Indeed the Alazzurra stands are supposed to bolt on. Sfortunamente, the center stand lugs (where the zura stand would mount) have been lopped off. Hence the TT2 - style RH fitment to the engine cases.
Trouble is, most side stands are fitted to the LH side of motorcycles.
The TT2 bike I rode around in Italy had a little piece of welded up pipe that fit perfectly under a bracket on the RH side. I'll challenge my welding shop neighbors to come up with something suitably elegant if I can't find a stand. But it's all academic until the bike arrives.
Eric W.
91 851
85 750 F1
80 Morini 500W
73 Benelli 250SS
67 Trail 90
97 F650 ST
Albuquerque, NM
