frame paint
nottonight68
- BLABBERMOUTH
frame paint
just had my frame painted-all theads are now clogged with super hard paint-goin out to buy set of taps-doh.should av bought cheap bolts to put in frame.at least i know the frame paint will be durable
cafe*racer
- SSD900 Darmah
- conti-mental
- Mach 3
What year is your bike?
My '75 900ss is a mix of metric and UNF - something to do with it being designed by Colin Seeley, perhaps?
I had to invest in a whole new set of taps when mine came out of the paint-shop. I have the details of the threads used *somewhere*...
The footpeg/silencer mounts and the swing-arm clamps are UNF, but the fairing bracket and transducer mounts are metric - wierd!
I'd welcome other views on this, but I think the 900's went metric in '77?
If this is helpful I'll be both pleased and suprised
Andy
Andy
nottonight68
- BLABBERMOUTH
frame paint
1976
fairing mount,horn- standard 8mm x1.25
transducer,chain guard 6mm x1mm
swing arm-8mm x 1mm
76 has bolted footpegs
frame-12mm x1.75
pegs-10mm x1.25
i havent adressed muffler mounts yet-still dealing with wheel re-lacing headaches
swing arm-8mm x 1mm
frame-12mm x1.75
pegs-10mm x1.25
nottonight68
- BLABBERMOUTH
7/16 bolts
Hi Andyconti-mental wrote:
<snip>
Yeh, many (all?) Bevel Dukes, including the wide-case singles, use 7/16 threads for the pillion pegs. (Don't know about the swing arm pinch-bolts, tho' - have always believed these to be metric fine).
Many possible explanations, each tending to be more unlikely than the last ...
nottonight68
- BLABBERMOUTH
.... nope. The Berliner Brothers sent a frame back to the factory with instructions to "make them like this" because they couldn;t get anyone at the factory to understand what they wanted for passenger pegs [or where they wanted them] and they had found some passenger pegs somewhere with the UNF threads.......... voila. thats what I heard and it could be right or wrong.........
