new head stem bearings
nottonight68
BLABBERMOUTH
Post by nottonight68 »
got new bearings-no grease in em-whats the type of grease to use ? or none
Any good quality wheel bearing grease will do. They must be packed fully don't just smear them with grease and install, you have to work the grease in between the rollers, cage, and inner race.
cafe*racer
SSD900 Darmah
Post by cafe*racer »
Marine grease, the blue stuff, is good as it repells water the best.
nottonight68
BLABBERMOUTH
bearings
be buggered if ill be riding in the wet. Anyway it never rains in Adelaide anymore :-D
Post by machten »
I'd be doing as suggested by wdietz186. Use a good quality bearing grease. It's thicker, stickier, and thats what it is for. If you're concerned about water ingress, you can even buy boat trailer wheel bearing grease (at least you could, I have a can of BP Energrease Trailer Wheel Bearing Grease - specificallyh for salt and fresh water environments - but it is many years old now). Bearing grease generally needs to handle higher temps and high spin rates (so it doesn't throw off through centrifugal motion) so it is thicker, like the consistency of cold jam you've kept in the fridge.
Post by machten »
Having said that, not such a big deal in head stem bearings, but i'd use it anyway, cause it will last longer and support the bearing rollers better. As wdietz186 said, pack em hard and full by working it right in.
machten wrote:Having said that, not such a big deal in head stem bearings, but i'd use it anyway, cause it will last longer and support the bearing rollers better. As wdietz186 said, pack em hard and full by working it right in.
+1 what he said. THis is very important
